Old 02-14-2016, 11:44 AM   #1
911monty
911monty's Avatar
Litronic Headlight repair
I recently picked up a set of used Litronic headlights. The driver side is fine aside from some yellowing of the lense. Passenger side is another story. I found the lens assembly separated from the adjuster side gimbal. The problem is the previous owner attempted to adjust the vertical axis in this condition. They ran the vertical mechanism up against the adjustment right angle drive and separated the lower adjustment screw. I now have two questions. First is how does the auto level motor disconnect from the lens connection? Motor is below the white transformer module in picture. Second does anyone have a broken right side headlight I could get the adjustment parts from? My initial repair attempt is to not separate the lens....yet. Might have to but I think I can do this without going that far. I have so far backed off the vertical adjuster and reattached the gimbal. Headlight is great except cannot adjust the vertical adjustment from the outside. Any advice from those who have disassembled a headlight is much appreciated. Thanks
