Old 02-14-2016, 10:55 AM   #1
The Radium King
The Radium King's Avatar
You can even fit a 235 on the stock front wheel (if the tire of your choice doesn't come in a 225).
Boxster race cars run with a set of rear wheels also on the front to get 255/40/17 on all four corners. But you'll need adjustable sway bars to dial out the oversteer (because that front end has huge grip with a 255 up front). I repeat, don't do this unless you have adjustable sway bars or it will drive like a drift car.
from what i've found, 225 front good match for 255 rear, and 235 front goes well with 265 rear. about to try 245/275 next.
