Originally Posted by spine911
Definitely a failing Oil Separator($80-120). Replace the part ASAP before your car starts smoking like crazy...Search under Renntech Forum for a complete write up of the whole DIY oil separator replacement.
When you replace the separator, also replace the oil filler tube. When the separator starts to fail it pulls a strong vacuum on the filler tube. The tube flexes back and forth and eventually cracks causing a leak.
