Old 02-12-2016, 04:47 AM   #1
JFP in PA
These cars are rated to have a 40-60 mA parasitic power draw maximum, starting about an hour after being shut down and locked (the draw actually starts higher, but drops off as system power down). If your car tests higher than that, you need to start tracing the electric circuits to isolate where the drain is coming from and contain it. The process to do this is simple and has been written up several times, so do a search and "all will be revealed"..........
