Old 02-09-2016, 03:38 AM   #12
Nine8Six
Nine8Six's Avatar
Originally Posted by PaulDash View Post
Thanks! Is that really it? The tank is much larger and will require a second pump. Any other items? Mounts? Electronics?
Paul - refer to the porsche-parts diagram for the parts needed. There is an additional pump you'll need, hoses, and if I am correct the in-car pull stalks will need to be changed as well if it didn;t come original with headlight washers by factory. Not 100% sure on the latest.
The windshield fluid tank is also not the same but could be quickly retrofitted with a T adapter I'm guessing. Not verified but wouldn't surprised if the case.
