Old 02-08-2016, 02:50 PM   #9
rfuerst911sc
Dualist it looks like the inserts you used are the same length is that correct ? Some other posts suggest that one of the inserts should be longer than the other. The theory is difference frequancies due to different lengths cancel the drone. So you are happy with how yours turned out ? Did you weld the inserts to the u-tubes and then insert into the muffler ?
rfuerst911sc is offline   Reply With Quote
