Hi,
i'm pretty shure the problem is not the engine mount or the mounting height. As far as i know the flywheels are balanced different, because internal masses are different and the 3.6 blocks of 996 engines differ from 3.2 986 blocks.
Another can cause of vibration/drone at this rpm range can be caused by the exhaust. But from what you've said i would say it's a balancing problem.
Regards
Markus
