Thanks for that. Cleaning it is a good idea. Need to also check the clutch slave. The stuff did look like brake fluid, and not a thick, viscous grease or oil. Do not know about the tranny oil change...can't say if it has ever been done. will need to check that. I did have it in recently to have the CV boot clamp replaced on that side, but that shoulnt have resulted in a tranny oil change. I saw where the loose clamp on the CV boot was throwing grease in the undercarriage, but the leaky stuff is not that.
