Old 02-07-2016, 02:58 PM   #24
KevinH1990
KevinH1990's Avatar
You probably already did this, but just to be sure - does your opener have a programming button on the side of the motor unit? Mine did and it takes a slightly different procedure. You need to press the programming button on the side of the motor and then within about 30 seconds press and release the button you want to program 3 times. It took me several attempts and I was about to quit when it started working.
Good luck.
