Thread: 05 997 s ims ?
Old 02-07-2016, 11:46 AM   #1
JFP in PA
Originally Posted by jdraupp View Post
Jfp, so with the 05s, it's impossible to determine unless you pull the motor and separate the trans in order to see the flange?
Actually, you want to look at the flange center bolt:
If the nut on the center bolt is 22MM, it is the non serviceable bearing, which is the only one that used that size center bolt.
