Old 02-06-2016, 05:10 PM   #18
Nine8Six
Nine8Six's Avatar
Originally Posted by amagalla View Post
I wanted to chime in here because I've done the speaker upgrade process. I did't have the rears originally wired in, so I had no wires running back there. Because of that, I had to run my own wires to the rear. This is pretty easy and straight forward. I did have the factory "Hi-Fi" system (the hi-fi used here is subjective), so I had wires running to the dash and doors. With out this option, running wires to the dash would be easy. BUT, running wires to the doors would be much harder. All electrical connections to the door go through a harness on each door. You'd have to figure out a way to run the speaker wires through that harness. I've no idea how you'd do that.
One nice thing about the way the older Miatas were built is that all of them were wired for every option. Even if the feature wasn't there (power seats for example), the wires were. It cut down on the production costs as there was no need to build different harnesses for different cars.
Hey Tony, hope all is well there with you!
If you would need to re-do all that, some latest kit are avail in the WI-FI range with pretty fast mhz processors. Can easily playback FLAC content as opposed to old Bluetooth which couldn't Converts your wired/3.5mm/RCA speakers in WIFI-speakers is what it does really (screw wires). You can get those kit in 2, 4, 6 or 8 channels for $60 or little more. Sure you can now find those on eBay. If not you'll see them soon enough, haven't searched.
That what the BoxxBoomBox looks like here. Looks smarter with the fabric cover. Subs, mids and all in one 90cm wide package (also wifi). Fits like a glove, sounds orchestral-ly beautiful, 150 watts, etc (kindly retrofitted by mfg for DC current).
My Sepultura Kairos album finally works in my boxster car lolllll
