Old 02-06-2016, 08:26 AM   #11
Qmulus
inveniam viam aut faciam
I have a stock '03 S muffler that I will be selling as I put a PSE system on the car. The tips on the '03 and '04s attach with a clamp over the middle seam on the top and one bolt on the bottom. The exhaust exits on the muffler are almost flush with muffler and just dump into the tip, which is contoured to fit fairly tightly to the muffler.
I believe 8/02 and later production was all '03 model year, so if you have a '02, they you have the welded on tips.
You could probably cut off the tips and weld on a bracket to bolt the tip to if you really wanted to. This picture of the '03/'04 muffler shows the mounting bracket without the tip.
Qmulus is offline   Reply With Quote
