ITR? Minimum weight 2830 lbs with driver, right? So 180 lbs more than Spec Boxster?
Minimum weight for E Production Boxster is 2555, or 95 lbs less than Spec Boxster.
The SCCA also recently approved the Boxster for STU.
In EP, you can eliminate a lot of drag:
