Agreed that there are a lot of variables here, and no one can tell you for sure if it will work in advance or not.
I have a spreadsheet that I made from measurements on my car, and plugged in this wheel size and offset with certain tire dimensions, and it looks like it would work on my car up to about a 10.4" tread width measured on a reference 10" wheel.
All tire dimensions are different, so carefully check the numbers on TireRack or the tire manufacturer's web site.
As always, your results may vary...
Please let us know if it works or not with a particular tire to add to the data base. If you have problem making it work, you may be able to have someone roll the fender lips in if it is close.
Good luck.
Kippis
986S
991S
Van Diemen RF97
