Old 02-03-2016, 04:55 PM   #12
ol doc gully
Originally Posted by flaps10 View Post
That transmission housing is a puzzling statement. It could just mean the magnesium casting at the rear end of the transmission that the exhaust system hangs from. If so then head to ebay and find one for cheap.
If it means that the actual transmission housing is damaged and needs replacing the total cost will be much higher (and probably not worth it, since you can obtain a good transmission for not much money).
Indeed, this is what worries me the most. Price on the part is $900 though and dealership didn't seem concerned so I presume its not a truly integral part of the trans, sounds like it is likely just the mag housing at the rear of the transmission for exhaust to hang from. This is a separate (bolt on) piece?
ol doc gully is offline   Reply With Quote
