Old 02-03-2016, 03:37 PM   #10
flaps10
flaps10's Avatar
That transmission housing is a puzzling statement. It could just mean the magnesium casting at the rear end of the transmission that the exhaust system hangs from. If so then head to ebay and find one for cheap.
If it means that the actual transmission housing is damaged and needs replacing the total cost will be much higher (and probably not worth it, since you can obtain a good transmission for not much money).
flaps10 is offline   Reply With Quote
