Old 02-03-2016, 02:00 PM   #14
jdraupp
Just had an alignment done
Toe was off on the front
Now have 0.03 total toe front and 0.10 rear
also camber went from -.9 LF -.4 to -.9/-.7 (maxed out)
I had them check the components for wear and they said all was good
Still have a vibration starting at 80 MPH. Gonna have the balance checked
Also still have a drift to the right, Castor is 8.0 LF and 7.6 rt. Looks like the only way to fix that is the Wishbone Adjustable With Eccentric Screw and it is ~$450 rather than $100
It's possible that the wheel weights that assist in tire balance have come off. You could tryou getting your tires rebalanced. How old are your tires?
