Easy job. Just jack up one side first. Then see if you can get someone to grab the wheel front to rear and rock back and forth while you look for play. Pay special attention to the ball joint on the track rod and control arm ends. There should be no movement. If there is then see if you can determine where.
PS: for clarification leave opposite wheel on the ground. This will prevent movement through the steering rack.
Reason: add PS.
