Old 01-31-2016, 07:03 PM   #1187
Nine8Six
Nine8Six's Avatar
Originally Posted by jaykay View Post
Could you render these views with tourismos to compare.....?
The next trick is to slide another smaller diameter projector in there and redo the deflector cup to take it....and then electrical? I see lots of room there!
Jay mate, not in an ideal position to toast those for you right away but will get them done. I'll get the 3 series lined up, not in Iguana green however. That green rendering belongs to a member here btw (sent you his youtube channel by pm)
RE dual-projectors. If one day I feel that there is a strong demand for dual-projectors I might consider throwing the required R&D and time into this. Atm you are the second guy who asked for this. And as you've already guessed, it would indeed need a serious redesign of the stock headlight. The Bi-Xenon Projectors you see now are designed with an emphasis on simplicity and really, that what works for the majority. Effective, safe, lightweight, easy-to-install, what else... ah yes; reasonably priced (important).
ps: if you want a guesstimate for a quality & functional quad-xenon, by all means feel free to PM - I'll make those for you with passion. However something tells me you'll change your mind as fast as your idea came up +$$+
