Old 01-30-2016, 12:18 AM   #17
geraintthomas
geraintthomas's Avatar
I've been reading this thread with interest trying to figure out why it will NOT work and I can't see any reason that it should not work as intended.
When the top raises and lowers you are supposed to press the button until the dash light for the roof goes off, but if you hold it longer there is no issue as you can hear that the roof motors have depowered and shut down in any case.
Of course this solution does not have the convenience of the auto Maintenance position but using the key to stop the roof seems fine.
The only worry is that if the car can be in motion with this mod and for some reason you need to stop the roof, the only way is to use the ignition key...not good.
So as long as the parking brake must be engaged your mod has no issues in my opinion.
Nice work coming up with this idea.
I already have the arduinos so I'll build the more advanced roof DIY switch.
To fix that, you wire up a third relay that makes or breaks the power that feeds both original relays, so if you press this button, the roof will stop. You can then name it 'emergency roof stop'.
I'll probably order a timed relay and try it just for the hell of it as, if it works, you can wire up said relay for 3 seconds which would make the roof open enough to service the engine
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
