Old 01-28-2016, 11:37 AM   #7
Smallblock454
2003 Bosxters don't have spark plug tubes.
Jack the car up on the left nack side, remove the wheel, go below the car and try to check where the oil s coming from. If you can't see, because there is to much oil than clean everything up, take the car for a ride jack it up again and check if you can see now where the oil is coming from.
Above the area you've filmed is a sensor. Maybe the leak is caused by that.
And if it's possible please make videos that don't shake the whole time.
Regards
Markus
