Thread: DME programmed?
Old 01-28-2016, 10:27 AM   #1
JFP in PA
Originally Posted by Xcellr8 View Post
Thanks for the reply. No upgrades to the engine. The original engine was toast after IMS bearing failure. So I personally swapped in another 3.2. That motor was bone stock. I will double check the engine number, but I believe I did that when the motor was first unloaded from the carrier.
I suspect this crazy power is coming from the tune. During the swap, of course, the engine harness plugs into the DME. It was in its stock location and appeared stock. If there were a chip, where would it be? I assumed it would piggyback on to the DME. Not seeing that only leaves a software change to the DME. Can a PIWIS show that? And, will PIWIS leave the program alone, or try to write the stock program over it? I wouldn't want that.
Surely someone here has flashed their DME and knows what "finger prints" are left behind. Thanks, Joe
I am not aware of anyone doing "piggy back" chip setups for these cars; most vendors reflash the DME. A PIWIS can detect a non factory flash, but will not overwrite it unless instructed to do so.
