Old 01-26-2016, 06:40 AM   #1
Gilles
ABS and pad wear sensors
last weekend I replaced the front wheel bearings but failed to properly mark the position of the ABS and wear pad sensors, both of these plug into a single connector
on the front top of the wheel hub, the connector has two plugs, on top and bottom, and looks something like this:
___________
[ top ] .
[__________]___._________________
[ bottom ] cable harness
[_______________________________
Could someone please tell me if the ABS sensor connects to the top or the bottom connector?
Thank you in advance
PS: I am getting now flashing lights switching from ABS Failure and PSM Failure..
Gilles is offline   Reply With Quote
