Well Koni didn't come through with Dyno results. They did send the following. No clue what it means though..
Monty,
Thank you for contacting us here at KONI NA. Unfortunately, I do not have Force v. Velocity graphs readily available for each of the dampers offered. I can however provide the factory specs at which the shock are tested to for quality control.
Tested at .33m/sec (13in/sec)
Front FSD- 8745 1328
Compression 350N
Rebound 1350N
Rear FSD 8745 1329
Compression 900N
Rebound 1650N
Sports
Front 8741 1573sport
Compression 500N
Rebound 1250N
Rear 8740 1574sport
Compression 1050N
Rebound 1550N
Mason OHara
Technical Sales Represenative
KONI - an ITT company
1961A International Way Hebron, KY 41048
(859) 586-4100, (859) 488-0324
mason.ohara@itt.com
KONI NA | Home www.koniracing.com www.konirv.com
