Old 01-24-2016, 11:03 AM   #7
Gilles
. And yes, while it can only go in one way, I was able to bend a pin once and even though the connector was seated, the bent pin kept the car from starting. .
+ 1
I went nuts trying to find the cause for an engine that would start backfiring as soon as you touch the gas pedal and dying after installing the OEM throttle body.
The fault was a bent pin inside the connector, I was able to bend it back without breaking it (they seem kind of fragile), be gentle and proceed with care.
Good luck!
Gilles is offline   Reply With Quote
