Old 01-23-2016, 03:46 PM   #1
j911brick
Then your friend needs to go back to school; both the PIWIS and the Durametric system can activate the VarioCam units, one at a time so you can see the unit's response in the real time cam angle data. You would also note a significant change is the vehicle's idle when the cam moves as well.
But that wont tell you what the problem is. Its only a clue as to where to look.
j911brick is offline   Reply With Quote
