Thread: The unlucky 1%
Old 01-22-2016, 11:27 AM   #19
JFP in PA
Originally Posted by arthrodriver View Post
Finally:So the LN fix is similar to a cam running in machined webs with oil feed holes?
No fist fights intended , but how about the oil analysis. They use it in aircraft engine analysis, right, flaps10?
Edit: You tube said something about an electronic monitor of the IMS??? Hype?
The LN bearings (non Solution) are ceramic hybrids that are sufficiently lubricated by the oil mist inside the engine. They do not require any other modifications to work, and some modifications actually reduce their effectiveness.
Oil analysis (that is, a complete analysis rather than a partial one) can tell you a lot about your oil, and a little about your engine. Some labs claim to be able to provide you with a complete analysis of your engine condition by looking at the oil, but you should take that with a grain of salt. They act more like a compass, giving you a sense of direction rather than a GPS telling you exactly where you are.
LN does produce an oil monitoring sensor (Guardian) which is effective, but only in limiting the amount of damage done when the IMS fails. It is not capable of preventing it from failing, only alerting you earlier in the failure process.
