Yes everything will work fine (water temp, fuel level, speed, voltage, oil level check, oil pressure light). You will need to change the oil pressure switch on the engine to get the gauge to work.
You may also need to have the VIN transferred into the new gauge stack if you have a stock radio otherwise you might have issues.
There are individuals here that can help you do that...for a price.
