Old 01-21-2016, 02:59 AM   #10
JFP in PA
Originally Posted by epapp View Post
Is any amount of oil in the j tube acceptable with a new AOS?
One purpose of the AOS is to pull a low vacuum (5 inches of water) on the engine case. In the process of doing that, it is going to pull some oil vapor into the tube.
Again, check your vacuum level, if it is correct, nothing is wrong with the AOS.
