Old 01-19-2016, 03:19 PM   #1
littlewiggler
(Copy of email I sent to Durametric support - hope maybe someone here may have an idea)
I just received my Durametric Enthusiast.
I was able to connect it to my 03 Boxster. No codes (Yay!)
I have installed the OBC stalk, and it appears to be installed correctly. If I move the stalk in any of the directions at start up the oil level screen goes away.
I have tried to enable the OBC via the Durametric but have been unsuccessful.
The first time I try I get the following error:
Coding Change Failed
If I try again I get:
Did not receive the correct number of bytes from the control module.
If I try a third (or any consecutive) time it states that it is enabled (but it is not)
Same happens when I try to disable it.
Any ideas?
littlewiggler is offline   Reply With Quote
