Thread: The unlucky 1%
Old 01-19-2016, 05:01 AM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by ksjohn View Post
I am kind of taking the attitude that even if I do find some very small metal particles in the filter, I am just going to change the IMS, flush the oil and hope for the best. I don't see that the 2.5 engine is worth tearing down. Even if I do it myself, it would cost more than a used engine. So, I am probably going to fix the IMS, put it back together and see what happens.
That being the case, I would highly recommend using the Pelican Parts IMS Kit that Wayne linked, rather than going with one of the more expensive LN kits. If properly installed, it should last as long as a clutch.
When you do the IMS Bearing be sure to follow Jake Raby's procedure of locking cams with the engine at TDC, rather then using the set-screws included with the Pelican Parts kit. People have had the IMS shift or set-screws fall into the engine.
