Thread: The unlucky 1%
Old 01-18-2016, 10:21 PM   #11
flaps10
flaps10's Avatar
I had your story crossed up with the other guy who had his engine make terrible noise and cut his filter open to find a mess. Two recent members that lunched engines i guess.
If the IMS bearing really came apart you have two immediate risks. First that your valve timing (re: "deviations") will be all over the place, and may have had valves and pistons colliding. Second, your engine pumped broken the debris through. Those pieces can't exactly fall from their normal locations into the pan. Judging be their appearance they took a trip through a timing chain sprocket or oil pump.
The sad part about the M96 engine is that you can't determine the extent without tearing it downand the risks of collateral damage is high.
I hope I'm wrong though
flaps10 is offline   Reply With Quote
