Thread: The unlucky 1%
Old 01-18-2016, 08:49 AM   #11
JFP in PA
Originally Posted by arthrodriver View Post
JP thanks, As an "outsider, however, it is not clear to me that the "solid bearing" is the fix. At least one knowledgeable diy person here stated the solid cannot be implemented. On the you tube I watched it seemed like they were pressurizing a ball bearing. Also does the solid bearing approach somehow run the journal on aluminum inserts, or is machining done for snap- in conventional bearing inserts. Please note this is not criticism, just trying to understand. Not an owner but admirer .
Then you need to let that person know that shops are installing them everyday, and they work.
This is the IMS Solution:
It comes in both single and dual row bearing sizes, has no ball or rollers of any kind. The bearing surface is coated with DLC ultra durable coating. It is oiled by a line running from the spin on filter adaptor to the unit, and is a patented design:
This system basically mimics the incredibly strong lay shaft bearings used in the Mezger designed and nearly bullet proof 996/997 Turbo engines, and is the only replacement system that does so. Some of the aftermarket oil fed systems are simply squirting oil on the back of the OEM steel bearings, which is actually not a good idea as it can lead to problems both with the ball bearing IMS, and how they source the oil feed has created other problems as well. The IMS Solution system works flawlessly, and is the only permanent IMS retrofit.
