Thread: The unlucky 1%
Old 01-18-2016, 08:11 AM   #11
arthrodriver
JP thanks, As an "outsider, however, it is not clear to me that the "solid bearing" is the fix. At least one knowledgeable diy person here stated the solid cannot be implemented. On the you tube I watched it seemed like they were pressurizing a ball bearing. Also does the solid bearing approach somehow run the journal on aluminum inserts, or is machining done for snap- in conventional bearing inserts. Please note this is not criticism, just trying to understand. Not an owner but admirer .
arthrodriver is offline   Reply With Quote
