Old 01-15-2016, 04:56 AM   #16
Jake Raby
Engine Surgeon
Originally Posted by paulofto View Post
My LN Guardian plug is leaking slightly as well. Only since my last oil change. The first 2 changes after installing there were no leaks. The car is in winter storage right now.
Would using 2 aluminum washers be of benefit in this situation? If not, how can I go about getting a replacement plug?
It sounds like you should break torque, spin the crush washer 1/3 turn and retorque.
Double stacking crush washers sometimes helps to overcome sump
Plate deficiencies, or in the instances where the sensor contacts the inner diameter of the sump plate with the outer tip of its hex head.
A replacement sensor is available through my company.
US Patent 8,992,089 &
US Patent 9,416,697
