Old 01-14-2016, 06:09 PM   #2
DarkStar
DarkStar's Avatar
Originally Posted by Steve Tinker View Post
Fuse C3 on your 2001 car controls the alarm control module, the interior lights and the power windows.
That was a foolish thing installing a 40A fuse instead of a 15A fuse - you have not only burnt off the conductor insulation but could have seriously damaged whatever piece of equipment was causing the original fuse to blow & just as easily burnt your car to the ground.
Just hope its not damaged the alarm control module.....
Screw the alarm control module lol. Worthless junk is all it is. Factory alarm keeps killing remotes, not about to pay 400 dollars for another when an aftermarket will do its job and then some. And it wasn't a 15, it was a 30. I didn't know it was only supposed to be a 15. The first Fuse blew was a 30. I figured the 40 would pop also. But figures it was originally a 15. My luck.
I was thinking the relay for the windows popped it. Since that's what I was doing when it popped. But I have noticed lots if the wires are poorly shielded. Doing the radio, a shielded wire has just fallen and hit a ground source and popped a Fuse. It's happened a lot. That whole center console unit, the power wires can be shorted through the Sheild just by tapping them to a ground source. It's very disturbing.
Thanks. I'm pulling dash apart soon to dye it, I'll repair that wire. And look for its short. It's either a relay or like I mentioned, a wire arcing through its shield to short out. Just gotta follow it.
Sent from my SM-G925T using Tapatalk
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
