Side Rocker panel install
Hello,i managed to get some Techart side skirts for my 03. They are being painting to match car. Question. When you do maintance like change the spark plugs/water pump and other things in that lower under neith part of the engine. U have to take off the OEM gaurd and then the inner plastic fender guard to make things easier to work around in there no? If i put the rocker panels on will that not restrict me from taking that inner guard off? as in i would have to peel the rocker panel off again from the 3m tape? is there a way to work around this? or does it matter? thanks.
