Old 01-12-2016, 11:11 AM   #20
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Dubaday View Post
... I found out that my IMS Bearing is a dual row IMS. Is this better than the single row IMS?
Is there anything else that anyone would recommend changing/replacing while the tranny is off?
Dual row bearings last longer and fail less often.
Consider changing the coolant expansion tank if it is original and the AOS. Also, while you are poking around in there it may be a good idea to replace the vacuum hoses on the engine. The old ones are likely to be brittle. How old is your water pump? AOS + Coolant tank + Water pump (and 160 degree thermostat while you are at it) = about another $1,000, but its well spent if you are having the down time anyway.
