Old 01-12-2016, 07:39 AM   #15
geraintthomas
geraintthomas's Avatar
It's possible, as I did exactly the same thing.
Years ago with my old Celica T-Sport at the Brecon Beacons, I was pulled over and decided to see how the car would set off with quite a harsh launch. Needless to say I didn't do it again as it slipped in a few gears for about 10 minutes later, and about an hour later I had to engage gears with a huge amount of force.
The thrust bearing was the culprit, but they obviously come as part of a clutch kit and is part of the procedure in changing a clutch. Basically what's happening is that the clutch isn't releasing all of the way when it should when your foot is pressed down.
To test this, go on a flat piece of road and put it in first. With your foot on the clutch, the car would creep forward ever so slightly (or stay still on a slight slope). When you take it out of gear, the car would return back to normal (or start rolling backwards on a slope).
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
