Thread: Car Won't Start
Old 01-12-2016, 08:37 AM   #1
cornontherob
cornontherob's Avatar
Car Won't Start
So I picked up a boxster on a trade. It's a project car so I understand the risk of it. I noticed that the shift cable doesn't always get the car into park, and has to be pulled on the transmission side before the dash registers that it's in park and not a blinking reverse light. So when it finally thinks that it's in park, and it is in park, it won't start. I turn the key and the fans turn off, but no power seems to go to the starter. I tested the starter with an outside current and it cranks fine. I also jumped the battery and fully charged it before I attempted the start. Could this be the immobilizer or the neutral safety switch? Would this throw an engine code? I don't know if it's the immobilizer ecu though because the only symptom is that the car isn't sending power to the starter.
cornontherob is offline   Reply With Quote
