Old 01-11-2016, 12:13 AM   #11
TrumpyAl
Originally Posted by geraintthomas View Post
Not yet, haven't had chance. How did you think it was from the headers?
Apparently using a heat gun doesn't apply heat in the right areas
I could be wrong of course, but it seemed to be only a single cylinder or perhaps two leaking. Only happening at certain temps is consistent with a cracked header/collector too. Eyeball your headers first is all I'm really suggesting.
I guess the headlights are sealed with butyl rubber as per most lights, but the sealing point isn't around the outer edge of the light like 'normal'. That's damned annoying that is! Especially when the right projector shrouds really lift these headlights appearance wise.
TrumpyAl is offline   Reply With Quote
