Old 01-10-2016, 11:19 AM   #2
boxxster
A reasonably sized wheel spacer is not going to ruin your suspension. There is no difference between adding wheel spacers and putting a wheel on that is the same width and diameter but a slightly lower offset. Either way you're pushing the wheel outwards and it will be putting more leverage on the suspension. If you go with a spacer no bigger than 10-12mm, I can't see there being any problems. You'll still be far better off than the people who put 10 and 11" wide wheels on these cars.
