Old 01-08-2016, 01:48 PM   #1
oc-boxster
oc-boxster's Avatar
I would have a Porsche mechanic verify with codes that it is in fact one of the cats, you have 2 how do you know which one it is? They also have heat shields that come loose that cause noise sometimes too. You could just have some type of a bad exhaust leak somewhere. If one of the cats is bad you will get a check engine light on the dash. Find out exactly what's wrong before you just start replacing parts.
oc-boxster is offline   Reply With Quote
