Old 01-07-2016, 10:26 PM   #3
jakeru
I am doing a similar project on my 986 (although on a much larger scale... Interior parts are laying around everywhere right now) and am planning to use SEM Color Coat Satin Black #15243. They had color swatches of it in stock at the auto body supply place I bought it from and I held up a factory soft touch black (2001 boxster) interior piece next to it, and it seemed perfect.
I am debating whether to clear coat it with 2-part polyurethane semi-matte clear coat (spray max 368 0067) for even more added durability. The auto body guy steered me away from the flat clear, saying it wouldn't match.
(Although I am still debating whether to bother with the 2-part polyurethane, as I was quite impressed with the apparent durability of the SEM Color Coat sample I looked at and handled... could not scrape it with my fingernail even after trying pretty hard.)
Before looking for the specialty products, I did a test of some very inexpensive "ultra flat black" camo paint from rustoleum. It was far too flat after being sprayed, but was actually a very nice color match after treating it with 303 aerospace protectant, as I read it would be on some VW or Audi forum. I was concerned about its durability enough to decide against doing my whole boxster interior with it, though. (This is not a job I want to have to do a second time!)
Getting off the old soft-touch finish is a chore... I've tried quite a few different things and nothing working all that easily. Some if it (such as on armrests, for example) comes off much easier than others. The plastics and textures used are not the same across all the interior parts. I've been scraping the bulk off with a plastic razor blade, and then getting the last part with a scotch brite pad scrub. Hot water seems to help a bit. Isopropyl alcohol helps somewhat, as does brake fluid. But still, it's a lot of effort required (and I'm probably about half way done with it so far - still have the center console to do, and those sill pieces you pictured!)
Before spraying the SEM Color Coat, I plan to use an adhesion promoter (which is basically a primer for plastic) after also prepping with grey scotch brite pad and having all old soft touch finish material removed.
2001 Boxster
