Old 01-05-2016, 07:11 PM   #1
Gilles
Originally Posted by PorscheFan5 View Post
Hi Gilles,
Weekend for the pics will be just fine. I am located in San Francisco Bay Area. Not driving distance for me to come by and check out your setup... However some pics will help before I tear apart the rack end fittings...
I am thinking it will probably be better to use a 45deg fittings or 90deg fittings to weld to the stock tips?
Thanks!
PorscheFan,
Yes, you will be welding the AN fittings (45 or 90 degrees) directly to the OEM fittings that are attached to the steering rack, the OEM fittings are held to the rack by a metal plate and single bolt.
You will be cutting off the thin (pressed) aluminum 90 degree tubes.
The factory O-rings keep the OEM fittings from leaking…
