Thread: IMS failure???
Old 01-04-2016, 09:33 PM   #23
Smallblock454
Hi sepesusi63,
first thanks for the update. Think you're right with your diagnosis - first ims failure and than failed all other things.
Hope you can get everything cleaned up. Sometimes it's hard to get all debree out of the engine. I recommend to clean everything really really careful.
Hydraulic lifters: to be honest - i would recommend to replace them all.
You didn't mention the chain tensioners in your listing. I would also recommend to replace them all.
Also i would recommend to replace piston rings and crankshaft bearing shells and inspect the cylinder liners carefully.
Because the engine and gear box is out of the Box check the 2 mass fly wheel.
Regards from Germany
Markus
