Thread: IMS failure???
Old 01-04-2016, 09:00 PM   #21
flaps10
flaps10's Avatar
I just saw your tear down pics. Damn. You might be able to save the crank shaft and bearing carrier. Have it all ultrasonically cleaned and the crank checked for straightness and magnafluxed.
That IMS is garbage.
You're right, the toughest part is deciding what you can reuse.
Were any rod bearings spun or have you torn it down that far yet? Don't forget to order the tiny oil nozzles that go in the bearing carrier.
flaps10 is offline   Reply With Quote
