Old 01-04-2016, 06:39 PM   #3
F18febe
Yeah, I knew you would say that, Particle. I've read just about every post you have on the GT projectors and I have seen your work. Very impressive. Once I get my corner trim pieces put back on and the car washed and waxed then I will post a few more pics.
The hardest part of this project was getting the paint to look right on the inner shroud. After the 5th coat, I put the shroud in the oven for 20 minutes on 225 degrees and that cured the paint very nicely. I used VHT satin black paint. Thanks for sharing all of your knowledge. Couldn't have completed it without reading your posts.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
