Old 01-04-2016, 05:26 PM   #16
KevinH1990
KevinH1990's Avatar
Originally Posted by boxxster View Post
-When I turn the projectors on, the drivers side headlight (the one I didn't replace) turns off after a few minutes. If I switch the headlights off, then back on again, it will come on for a few minutes before going off again. I think this might be the bulb or the ballast? I have a spare ballast from the damaged headlight that was included with the car and a bulb isn't too expensive so either way I'm not overly concerned.
I suspect that it is either the ballast or your headlight switch. Trying swapping a ballast that you know is good into the headlight that cuts off and see if that solves the problem. Search this forum for "headlight switch" and you will see that it can be a weak component.
Regarding your failure to bond with your Boxster. When I bought my Boxster I didn't feel the immediate thrill that I felt when I bought my Miata. However, as time went on I've found the Boxster to be a richer experience. Give it some time and I suspect it will grow on you.
