Old 01-04-2016, 11:09 AM   #21
DWBOX2000
I just did the wp on mine last week. It was pretty easy you just need to get your hands on a torque wrench that does 84 inch pounds. No leaks so far though I did add too much fluid. Since fixed. If you decide to do, disconnect battery, remove seat, do and then put seat back in then connect battery. Won't have to deal with airbag light that way.
Oh, I used regular water. Hopefully that won't be an issue down the road.
The worst part was getting rubber hose off pump. JP had posted an earlier message about it which really helped.
Good luck.
DWBOX2000 is offline   Reply With Quote
